Hi Carina,
If there are any forms that are a particular pain point for your company now, I would start there. If they’re all the same, I would suggest starting at the end of the quality event handling process and working your way backwards. For us, this meant starting with CAPA because for most things, that is the end of the line. Then we went to Issue Review, then Nonconformance, then Deviation, then OOS, then Complaint, and Event Report last. That way, as you add on new forms, you’ve already configured the forms that they could launch into. This attached picture I got from a session at Summit and shows how things all work together. Start at the end (MOC or CAPA) and work your way backwards! Do note that Customer Complaint, OOS/OOT , and Deviation can all flow into Nonconformance.
